Seeing as the old girl is knocking on a bit I was wondering about what oil type and grade to go for this time as its due a service.
Mineral or semi? Normally use a semi.
knocking on for 200k on original engine. :thumbup1:
  • Replies 25
10-40 fully and add a forte clean and protect, the clean is a flush you run before you change the oil and the protect is an additive you add to the fresh oil 👍
How old is the vehicle? Not sure what the logic is in sticking a super high performance, bells and whistles oil in a relatively old machine. It may give you extended drain, but at the end of the day whats the point when it cost 2 -3 times as much. You may as well change your oil regularly and carry on using a semi or even a mineral 15w/40 does the job.
Our rep ( now retired) ran a old Renault 12 on our mineral 15w/40 and took it all the way to 350 k, same with our oldest tanker it is now on 400 K +
Financially, how do you view it. For me, engine durability is the utmost priority irrespective of initial outlay - it saves £ in the long term. But I agree that more frequent changes of "general oil" is a legitimate option; not as environmentally sound though; unless you heat your workshop in a used oil burner or recycle the UO some other way. I'd sooner spec an SHPD Mineral such as URSA to semi-syn. Meaningless phrase anyway; comma oils are "fully synthetic"; and yet <20% of the product is such; marketing rubbish :001_rolleyes: and still an acceptable OEM approved product.
