The 261 responds well to muff mods, too. Just make sure you don;t point the port at the brake handle The 241 has loads of room under the bonnet for ports.
I also have two more ports on the other side to be safe. Eventually, she'll be ported. Not because I want more power - she has loads. I want better throttle response. I made the mistake of running a ported 42 special once.
Remember to reset after the mod. Let idle on "Start" ^ for at least 60 seconds(I count to 90), shut it off so it saves the idle parameters. THen 5 full cuts similar to what I have in the vid, and she will be fairly well dialed in, and she will keep dialing it in as you use her,
Edited by wyk
  • Replies 32
WICKED !! :thumbup:
BTW, this is toolnuts old saw. He's got a 261 now. And it looks like that thing is gonna end up in my lap for some tweaks as well.
I had some 91SG in the 80's and it really put me off Lo-pro.
But watch these 241's on stihl chain - 325x1.6mm RS against 3/8x1.3mm PS
The Lo-pro is cutting 4 cookies to the 325's 3.:thumbup1:
and that's why I run mine on the picco .. . . it's a no brainer, especially in softwood:thumbup::thumbup::thumbup:
I don't see why the general tree surgeon type wouldn't run the picco chain, chain compatibility is then with the 200/201, so should anything go tits up, you have an immediate swap, carry half the chains, one size of file only and a spare bar, as opposed to a selection of files, assorted chains and different bars
Has any one ( back in the day ) run a Husky 242 and this Stihl and drawn any kind of comparison ?
242 has much better throttle response with a muffler mod. However, it has nowhere near the torque the 241 does. It is just a much better limber. With a good MM, the 241 comes in to it's own. It's just the price that scares me.
Exactly. And someone in forestry is going to lean towards 325 because that's what they have handy. When I use the 241, it will be for extended sessions for clearing rhodie etc, so a longer lasting chain makes a difference as well. Picco bars also just do not last long at all in a forestry setting before needing dressing or replacement.
