Yep as above post by TGB but there are x3 types of Sugi bars:
  • Laminated super light - tough laminated bars but they are not that light really - not as light as an oregon pro lite or some of the Stihl bars but def feel tougher and should last a lot longer
  • Pro solid - single piece steel bars - I think in terms of stiffness these are the best on the market compared to ALL other bar types (although no tests done to prove!). Using a 46" sugi pro solid on the 880 feels like using a normal chainsaw bar rather than something that flops a bit.
  • Light type bars - these are the pro solid bars - but with areas removed and filled with a tough resin. You do loose a smidge of the stiffness but weight saving is around 20% to 25% depending on bar. They also look the best -not that is matters but it is nice!
Vid on the light type bars here
They don't have to come with an adapter and in fact all the bars I have are made for the correct mount - but the next order will have a lot of multi mount bars running .325 .063 and 3/8 .063.
This means you can run them on both a Stihl or Husky + you only have to have 3/8 .063 chain if you run both types of saws. The adapter plates are getting better and really are simple to fit and remove (or will be!)
I did a vid on all the Sugi bars here which is informative if a bit boring!
:biggrin:
HI ALL i was told by someone in the no im not names as it not the right thing to do that ROB D BARS SUGI BARS are one best bars on the market and far better then what fitted on new saws now so there you go what your off doing is just by a new saw with SUGI ROB D BAR ON thanks jon
  • Replies 102
Thanks Jon :biggrin:
Good stuff Salty!
Next order is going in with them in around 2 weeks but it will be 4 months before delivery so end of Feb I'd say.
Good stuff Salty!
Is there a sugi for the 540xp rob?
I think your a very nice man as well as jon! :D
That's what I'm looking for too Rob, 12" sugi light for the t540xp how do I go about putting one in that order please?
Good stuff Salty!
Hi ROB would you have a bar there for a 661 thanks Jon
The bar will last about 400 years and the saw about 4 weeks ! :biggrin:
