Ms 150 tc
HuwBaldwin
Isn't it a common fault on these ?.
I bought one a couple of weeks ago, first thing I checked was chain oil being pumped out, also think I read on another thread with everything being so small they are fussy about oiling properly if you use thick oil.
Stihl synthplus fully synthetic chain oil was recommended as it is quite thin
Had exactly the same problem and posted it here. Sent it back to supplier who drained the Oregon oil and refilled it with Stihl Synthplus which did the trick...it's now using about 2/3 of a tank of oil to a tank of fuel (but you need to work it at max revs) and will probably use more as it beds in. The Oregon oil I use works fine in all my other saws but not the MS150 which is a bit of a pain but there it is. I'm happy with the saw apart from this little foible.
