Hi everyone.
I bought a 550 in November 2011.
So far I've got a new petrol tank, new oil bleeder hose, new side cover, 2 new magnetos/coils, 1 new piston ring due to carbon build up, one new engine rebuild due to carbon build up, and I'm just after breaking the 11th chain brake band.
I have 5 stihls, the oldest is 2009 and I've had 4 problems between the 5 of them.
So my question is this:
Do the "new and improved" 550xp's still have any of these problems?
Sent using Arbtalk Mobile App
Edited by brian hegarty
  • Replies 24
Just out off interest In regards to the carbon build up problem which two stroke oil have you been using?
We have only had one back as a poor runner, it was the ignition coil, but it's not like we have sold hundreds of them plus all of ours have been 2012 models onwards.
I've had one since apf 2012 and it has lived on an 18" bar since new so has done a lot of work for a 50cc saw but it's been almost faultless apart from 2 break bands. Since the upgrade to the redesigned break band I haven't had a single problem and it's still going very strong
It's an early 550, what do you expect... reliability?
The 2013/2014 ones seem to be pretty much sorted now. And there's now a beefier brake-band available for the 545, 550XP & 560XP.
If the brake bands keep going, it could be warping of the clutch cover.
Heavy coking is due to a high fuel and oil content in the mixture, this could be the carb, fuel you're using, oil or a blocked spark screen, but the cause for the coking should have been quite easily resolved by plugging the carb in.
Read more
