  • Replies 49
I just give the files a good few raps on something to clear the debris from it during filing every few teeth. Seems to keep them from loading up. I get quite a few sharpenings out of my save edges I get from Mackin Rob-D.
I used to use the save edge files, they were very very good, the last box I had didn't seem to last as long as the others though
also the hardness/grade of steel/ temper and some are chrome steel coated for longevity so its a minefield what file to choose i use oregon & save edge but i lean more to use save edge they seem to be less skiddy and take more off on each stroke so quicker to touch my chains up and crack on etc i use full chisel oregon multicut chrome steel chains as i'am ringing up dirty/muddy arb waste etc
didn't know you could get full chisel multicut chains, always thought they were semi chisel only ??
ian
On a new chain I give each cutter a rub with a rolled copy of the Sporting life then weld a knob on each raker ......
How much faster does it cut then? Does it have to be sporting life?
How long is your knob on each raker?
Can use the Racing Post and all my knobs are enormous .:biggrin:
