  • Replies 34
Right I got the axe out the shed and the head is a bit loose, how do I check how tight it should be ?
I've got no idea how to check an axe!! I just use the power saw:thumbup:
If it falls off, it's not tight enough
If it stays on you risk it being too tight though...
No matter how i tension my chain it sags after 1 cut.Touch the chain and its warm so cant be because of heat and yes saw is switched off before any comments.After a minute its right again.
Ditto :001_smile:
Just tighten the chain so it doesnt sag (big nasty bars excepted)but can be easy moved.
I prefer a tighter chain on top handle saws as I want the chain to stop spinning fairly quickly when I release the trigger.
If your chain is always slackening off then check that its getting some oil.
TBH its not rocket science, if it looks OK then it probably is.
I like the idea of using a chainsaw's powerhead like an axe. But with a sausage roll in place of the bar & chain. If the tree falls over, either the sausage is over-cooked, frozen solid or the tree got board and fell as a way of making something differenr happen. This last one, is partly dependent on the tree being sentient.
Mind, if the tree fails to fall over. It could just mean the sausage needs more cooking or isn't frozen yet or the striking angle is incorrect or more likely than the others - the sausage is blunt. Question for the experts here. After sharpening, how does one correctly gauge the tension of ones sausage? I mean, after correct cooking/cooling, should ones sausage have a slight sag or be stiff?
