using my husky t540xp today and realised that the chain tension was a little lose so i switched it off and then re-tensioned it.
just wanted to know are you meant to just see the bottom of the drive links when you pull the chain up after its been retensioned? OR is the bottom of the drive link meant to be hidden in the grove?
and also i put a glove on to pull the chain back and forward to see if it ran freely and its a bit of a struggle to do with one hand but quite easy to do with 2 hands, does this mean that the chain is too tight?
  • Replies 34
The links should be completely hidden in the bar rails and if you pull on the chain and pull it round fast, it should keep going round for a short period after releasing it and not stop dead.
The chain should also be smooth when pulling it round the bar.
i have herd different theories from different people , at college they said that you should be able to just see the bottom of the DL and at work i was told that you are not meant to see the bottom :confused1:
I like to be able to pull it and have at least one drive link come out, it should then snap back full in. And like spuds says run free and easy I usually put the combo spanner on the back of a drive link and push it forward to test free running as I do not wear gloves, I hate over tight'chains that noise it makes is like finger nails on a chalk board to me.
The 3 link rule is not a good guide, as it will vary on bar length.
on TH saws and pole saws, i run chains a little looser than i would ordinarily due to the low horsepower base your starting with.
chain should be loose enough to feel smooth on turning rotating by hand but not so loose there is chain creep on idle.
the 1,2,3 link thing...depends on how good your grip is and how hard you pull! 😜😜😜
Sent from my iPad using Arbtalk
I missed the bit about pulling up the chain:blushing: Thought we were looking at the bottom of the bar:001_rolleyes::lol:
TBH, I pull he chain up as I do the bar nuts up so the bar is pre tensioned upwards at teh tip - chocking up the end under the bar would have a similar effect. I then check to see if the chain hangs down off the bar and retension if loose and spin it round until it is semi tight on the bar.......it works for me!:thumbup:
When I taught I would say that, as a rule of thumb, 'place the saw on a level surface, take the chain brake off, hold the chain with a gloved hand and pull the chain; if only the chain moved, it's too slack, if the whole unit moved then the tension was somewhere near OK'.
I was told that too and I think it's rubbish. Incredible amount of variables such as the weight of the saw, length of the bar, grip factor of the surface. All these 'rules of thumb' do is confuse newbies.
In the end only mechanical understanding and experience will tell you if a particular saw is tensioned correctly. You can tell a lot by the sound made as you pull the chain over, or at least I can. You can hear worn sprockets like this too.
I only have up to 16" so I don't know about big stuff but I don't like to be able to lift the drive links clear of the bar so I tension it so they are still a bit covered when I lift the chain in the centre of the top of the bar.
