Half way through building my splitter and wondering what sort of spool valve to fit, it's running off a petrol power pack, also when the power pack is running and I engage the pump it stalls, I'm assuming when it's piped in this won't happen ?or is it knackered? Ta
  • Replies 23
I would imagine because there's no flow it stalls. Bit like lifting the clutch in a car too quick maybe.
That's what I'm hoping is the case!
If the pump is blanked it will stall the engine
You need an open centre valve, make sure its big enough for the flow on the pump
HI JOHN IN BOX FULL MATE THANKS JON :thumbup:
Cheers,
I would fit one of these
Monoblock Hydraulic Control Valve 1/2in 1 Bank DA Flow capacity 60l/m Max pressure 4410 PSI 250 BAR fitted with pressure relief valve. Port markings P= Inlet, T= Outlet. 1/2 1 Bank DA. £58+vat
This valve block has an internal relief valve fitted which is adjustable
Is it a chipper, is it a mower or another broken stump grinder who cares we'll fix it!
