Japanese Knotweed control?
Peasgood
I'm after a bit of advice off you knowledgable folk please.
In the spring I found a very small patch of knotweed on my place. It wasn't much at all and i thought/hoped that I had pulled it up.
I looked again yesterday and there are three spreading shoots that are a couple of feet high (not spears)
What in your experience is most likely to kill it?
I can spray with glypho, inject,cut,dig, burn etc etc. What do you reckon?
It is only very small but I want rid of it now.
defo glyphosate, it's the only thing that works - dig it up and you'll leave roots behind that come up again years later. spray foliage and inject stems ( i use a syringe that you get with printer cartridge refill packs for small amounts or a sheep vaccinator for larger infestations)
Having gandered through those I now know you should use glyphosate because Roundup contaminates the ground. (they are both the same thing!)
Injecting with neat antifeeze works but red diesel doesn't.
20 litres per hectare is the required glyphosate rate but anything above 5 litres is illegal and you are better off buying it off a farmer because they use stronger stuff. (I'd say 360 is about the same strength whoever you are)
Having filtered through what I can, I am going to spray the foliage with a strongish mix of glyphosate, a week later i will cut and bag the foliage and burn it and inject the stems with a 50% mix of water:neat glypho. The stems will be a bit shorter than recommended 18" because the plant isn't much bigger than that.
Any regrowth this year will get a good dose of something I probably shouldn't have.
Is this OK?
