hey jon, do you want to go around the country and collect the whole lot mate:lol:
I thought that was what I was doing now. :001_tt2: Got some more bits that may tickle your fancy: only got off the plane 4 hours ago so give me a day or two and I'll get you some pics.
  • Replies 37
steve cant believe you didnt ask me? if you had a week ago,,you`d have had loads,,,Ive gone through my pile and reckon you`ll get a set from stuff I sorted out today,,,as made mushrooms from the rest,,,also got two lengths of 5.5 x5.5 beech for you,,what happened to lignum?
didn't occur to me mate. i thought you wanted to use what you showed me for your own personal use anyway.
if your passing i'll take the beech mate.
the lignum was a right cock up. the delivered it with a truck that had no tail lift or pallet truck and it weighs about 150kg.
the next week they did finally deliver it on a tail lift truck only for me to realise that it was way too big. 12 3/8" was what i was told i was to receive and i got one that is 15" in diameter.
it is to be replaced with one that is 12 3/4" which is what the customer needs. i'll let you know when i have it so we can sort out the milling.
cutting it in to two 4' lengths will be fine. i should be able to make a couple of nice bowl out of something that size too.
Hi Steve,
The main trunk of the tree where I felled it near the base had some rot through it. Some of the stems had rot but there is a fair bit of 4" - 10"
diameter stuff that seems good. Didn't get a chance to go through it all thoroughly cos of time.. I did take a couple of photos on my phone...
Below.. I could try ringing up the trunk a bit to see how far the rot goes. There is certainly a pallet full of good stuff anyway.
Thanks
TimonImageUploadedByArbtalk1407184914.386573.jpg.c5e2c8fe60a0f0e7827fe1bee6b38bcf.jpg
Hi Steve ,
Here's some pics....
I'm away after next week so if you want to sort the pallet out this week that will be cool.. Otherwise I'll be back mid September .
I've got pallets and shrink wrap etc and I think I've got some pva.ImageUploadedByArbtalk1407703054.268519.jpg.565a1f5aa6b5cb2dd147011e4e56949a.jpg
I'll PM you my number..
Timon
  • 6 months later...
Bad luck mate. I've just given a 10' stem of 12" dia away to my mate for woodturning. I felled id it 2 weeks ago along with a decent cherry and a couple of hornbeam. I get to keep all the wood and get paid for the removals from my workshop landlord.
