Replacement for Pantin
Mark Bolam
If it's says Turbo, buy it!!
WHAT HE SAID!!
Sorry, did I shout that😳
Apparently the CT one is very good. I have the old and new Petzl Pantin and the new one is not as good.
With the new Pantin you want your rope to be 5mm thick to make clipping in easy, then it needs to swell to 16mm to stop it slipping out every 4 seconds.
PS: I should add that I've always really rated Petzl gear and realise that my technique may be at fault.
I have a left old Pantin and a right new Pantin.
Sent from my iPhone using Arbtalk mobile app.
Edited by Old Mill Tree Care
WHAT HE SAID!!
Nope your right mate ... the new pantin is crap
The CT is good. I have a new pantin for my right boot and a CT for my left. I stopped using the pantin. The only issue I have is the strap is starting to wear were it rubs on the metal on my boot. It take a fraction of a second longer to put on and you have to unclip it to get it off but it doesn`t pop out. And it`s cheaper.
