this is my first little beast now ive stuck a cheap and cheerful box on it :001_smile: already earned its money back, bought it cheap as chips had all problems fixed, simple fixes now its all working spot on.
love the delboy greedy boards:thumbup: but if it works then don't knock it:thumbup1:
oo yes they work a treat, and with the 18mm hardwood ply boards at 38quid a sheet and abit of black paint it sure is worth it :thumbup1:
I think you have a bit of moisture in your camera or Vaseline on the lens. Lol
Rob,
Regardless of the total train weight you can't go over on what the truck says I.e. 3210kg. Your license just means that regardless of what vehicle you are driving you can't pull a trailer capable of weighing more than 750kg full. You can't even pull an empty trailer capable of carrying 2000kg even if it weighs less than 750kg empty.
Your axle weights need to add up to at least the 3210kg assuming you have got the right figure for total truck weight limit otherwise you could never fill the van to it's read limit as one or both axles would be over their limits. There should be 4 numbers on the vin plate
Max vehicle
Max vehicle+trailer
Front axle
Back axle
Front +back usually = max vehicle
It could well be your navara is rated at 2700kg gross vehicle weight
That's right kev. I understand it, I was pretty sure on most of that anyway. Payload of 1110 is right. Wi a box maybe coming in less than 100kg and two blokes and gear maybe most of another 200, leaves me with about 700 to be safe. And 700 in there would be spilling over!
All this trailer malarky is a headache at times. I do understand it, I know that filling a 2.6t gross trailer with mesh sides with freshly felled logs then dragging them home at 35mph is overweight. So does the clutch! But that's for elsewhere :001_cool:
I can then put 300kg in the trailer and that would total that to 700, leaving me all legal. Which is surprising.
I'll have you know I'm technically not a student from 27th may to 6th June! Watch out! :001_tt2:
Test cricket: where did those boards come from? The 38 sounds a lot. Mine were 21.80 each for 5. They are 12mm though and WBP boards. 18 just seemed too thick!
