ooops
fergusonforestry
  • Replies 30
JB weld id good but in all honesty I think you need a new casting .
He's suggesting Lumiweld Stubby, it's an aluminium brazing rod not a glue. It works well if you can do it right. We once fixed a fairing bracket to an aluminium frame and it worked well. You need a good blowlamp to heat the metal up and get the paint out of the way before you start.
Yep ok . Worth a try .I am no expert by any means but the little I have attempted resulted in ..The aluminum is there ...its still there ....bugger its run away ! Nothing to loose ...give it a try ! :001_smile:
I had my 064 pull start casing bust. It was welded together. 1 pull it shattered again.
Ally rods r that ally, but casings are cast ally and contain everything but ally!!
Good luk.
Lumiweld is not aluminium it is a brazing rod for aluminium but it will work on pot metal and zinc based alloys as well as it has a much lower melting point than aluminium.
