well about a year ago arb members suggested i get some pigs to clear some land they did a great job, but now i have to bbq half one for family friends on a very large gas bbq has anyone done this before and if so could they give me the basics to doing a good job, my expertise runs to burgers etc so really dont want to bulls it up.
  • Replies 20
Popular Days
Do you have a link to the conversation about the land clearing?
What kind of an area did they clear?
Go for the Whole Hog and spitroast it, over a wood fire is far better than the gas coffin. Everyone will remember the day forever if you do.
Over logs a full pig will take around 8-10 hours so make sure you give yourself plenty of time to prep and cook. Main thing is make sure its cooked fully and don't give ppl food poisoning.
Whole thing over logs as said, I'm a bit hazy on cooking times but wouldn't have thought as long as 8 hours. Slicing the meat off you'll be able to judge fairly well if it's properly done or not anyway though. Mix oil, salt & pepper and brush on excessively throughout cooking, that and fire is all it takes to make it taste amazing. If you have a small electric motor lying about and can rig it up to the spit it will save you much bother.
Does it need to cook through fully. I'd think you could just cut off the cooked bits as you go so long as you've set up a bit in advance to get a decent bit to go at, you wont be keeping people waiting. I could be wrong though, only ever ate hog roast never done one
Don't forget for a spit you will need to keep the hog rotating non stop, so uunless you have a small child there all day you will need a motor.
But hog roast it over logs and your away, maybe some Apple wood.
The pig is already in half haed to tail and i will try find link but i used 4 gosx on around 2 acres did very good job. only access to large gas bbq but might try make log pit with grill
Cut a 45 gallon drum in half lengthways and weld it end to end for a makeshift firepit or something it hasn't got to be highly technical.
You don't want wood that flames up well, else you will just burn it up.
