  • Replies 24
Hi all
What's the best product to use to clean timber decking and best method of doing it?
Hopefully this is the right forum to post this in.
Thanks :001_smile:
A pressure washer does a good job of getting rid of slime and grime
Trouble with pressure washing timber is it ends up ripping the fibres so it looks all woolly. I don't mind doing it by hand but not sure what product to use on it that will actually work
in sweden we use a chemical cleaning solution to get rid of all the crap (scrubbing using a semi-hard brush), then rinse this thoroughly with a high pressure washer (not too close), then apply an oil to protect the wood. i wouldn't use solely a high pressure washer, as Ashes_Firewood mentioned this can cause a woolly effect and splinters if you like to walk barefoot.
cuprinol do a cleaner that i would probably use if i had decking at my home here in the UK: https://www.cuprinol.co.uk/products/decking_cleaner.jsp.
edit: forgot to mention also that you can sand the decking, if it's that bad.
Edited by luke_mclachlan
slight addition
I use dairy cleaner
Would that be hyper chloride (think the spelling is ok?) I use it for the hot tub & various timber products & algae on house / roof. Needs a careful application, gloves / goggles, it's like a super strength bleach so not fantastically environmentally friendly.
This is how they do it in nz
[ame=http://www.youtube.com/watch?v=hkmeoYKYctw]D*ck Maintenance - Banned Commercial! - YouTube[/ame]
