  • Replies 27
Thats going to denend on make and model Nige, eg: a tinnywolf 125 with a 20hp petrol is going to be better on fuel that say a 55hp diesel thats in my greenmech. I do find my Greenmech a bit thirsty on juice but it can knock some brash through in an hour. to run all day i reckon it would use 20 quid or so mybe more.
I’m not sure you’ll find figures on fuel economy for chippers – would be interesting to find out though. My BC100XL costs over £100 to fill up and lasts a surprisingly long time! I’ll make a note of the hours next time I fill up. Guess it all depends what your chipping and how heavy your working the engine…
I was wondering what the poular Timberwolf and Greenmech models were like.
I've never used either make.
I found the Kwik Chip 222 with the 27 HP engine very economical providing it wasn't force fed a lot of large stuff, but this was really too small an engine for a chipper of this size and weight.
The next 222 I had had a 45hp 4 cyl turbo engine and was well on top of its work and very economical with it.
I've used most of the Jensens and have one now.
As a direct comparison, the three cyl Kubota in the tracked 530 uses a lot less fuel than the four cyl engine they put in the same machine on wheels.
I found the four cyl Kubota very greedy on fuel.
I found the Kwik Chip 222 with the 27 HP engine very economical providing it wasn't force fed a lot of large stuff' date=' but this was really too small an engine for a chipper of this size and weight.
I found the four cyl Kubota very greedy on fuel.[/quote']
great chipper, on a full days chipping it may use half a tank = 2.5 gallons @ the mo a tank lasting all week, but having sharp blades helps the fuel go a bit further :001_smile:
i would reckon the engine not working hard would be the best, no stress really means the engine is too small. i can run the mog all day with a 10 inch chipper on about 12 gallons.
I can run a ten inch chipper all day on about 4 gall, get shut of the mog or get one of those new fangle electronic throttle controls that shuts the revs down between feeds, would be brill for a mog :001_smile:
no need dean, i have headsets, so i can shout orders from the other side of the building. if someone is doing something that is annoying me i can just say it, or if they need a little pointer on how to organise their chipping i can just tell them. and i never leave a chipper un manned, probably because its out on the street because it wont fit on the driveway:blushing:its all about flow of the branches, when its not flowing sweet. stop the chipper and stack.:001_smile:
