On my 6th pair of Hiflex now, never seem to get more than a year out of them, although I do like them generally.
How do they compare to Stretch Airs? And which type of Stretch Airs should I go for if I switch?
Comments preferred from people who have actually worn both, although I do enjoy a bit of completely off topic and inane babble from members who have no experience of the matter being discussed.
  • Replies 34
No contest mate. stretch air every time. get around two year per pair.:thumbup:
That would make more sense financially then, even though it's a bit of a stinger initially.
Are they as comfy to climb in?
Also, I am quite dwarf-like. You are a 6 1/2 foot giant are you not? Do you know if they do different leg lengths?
pretty sure you can get longer leg versions, seen them online somewhere.
Had mine for a year, really comfy to climb in, but can sometimes be a bit baggy.
Might give hi-flex a go after these are destroyed.
I get the all round protection, no worries for climbing in, although some do moan... I do get the extra 7cm versions though, that see's to the blessing it is to be over 6 foot.:001_tongue:
2 leg lengths I believe, standard and plus 7cm I have the latter as I’m also a L.S.O P ,:001_tongue: stretch airs are quite a bit heavier than high flex, but a lot more robust, also find them a bit hotter in summer even though they made from a material apparently derived from coconut husk,:confused1: supposed to make them cooler and less smelly, does seem to work a bit, still smell like a wet dog when it rains but not half as much as the old green sip ones I used to own :thumbdown:
