haha this is true, i still believe silkys are more dangerous than chainsaws! i have 3 scarrs on my left hand and 2 on my left arm from silkys!! one required 4 stiches!
Take it your right handed
Sent from my iPad using Arbtalk mobile app
  • Replies 93
Why not use a backhandled Stihl MS150 or equivalent. Incredibly light and nice clean cuts for pruning.
Would solve the problem and any concerns.
Exactly Jim. :thumbup1: great for wee stuff.
It may solve concern but would it solve the bank balance after buying another saw that's not needed?
HSE say "One-handed use should be restricted to circumstances where one hand is required to
maintain a stable working position and the saw is used at extended reach with the
other hand, eg while cutting at the extremities of limbs."
So it is OK to take chances whilst up a tree, but if you are standing on the ground, in a stable position using both hands, you can't use a top handled saw.
What a load of tosh. Is this the same across the rest of Europe?
Perhaps our European human rites are being infringed.
H-A
If you are kicked off a site,loosing work then £350 aprox is pretty cheap IMO
H-A
Exactly if anything you will be in the most dangerous position possible in the circumstances they mean, how do they justify working with 2 feet touching the flood more dangerous?
My opinion is it's fine to use a top handle on the ground for private and some commercial work like building sites, using one for the council or utilities is a big no no for a start if you cut yourself mistakes do happen you'll be sacked and you won't have a leg to stand on (my be literally) in an employment tribunal. I'd rather spend an extra 5 mins and either tie in or use a different tool. At the end of the day you work for the council you're in no big rush to make days money just take it easy and do as you're told by your supervisor don't mean to sound harsh but that's just the way it is with life sometimes
