Hiya
I have a tw150 35hp kubota, what engine oil does it take? I've had a looksy in the manual and I can't see it?
Also, I'd like a new battery for it. It takes a 063 which the one on it says 460amp I think. The varter 063 says 360amp, why the difference? A bigger amp varter wouldn't fit where the battery sits?
10w-30 not a lot of places have it though as I found out when I tried to purchase a load! My company has just got some new ones to maintain and the 50hr service soon comes!
  • 1 month later...
DIESEL ENGINE - OIL VISCOSITY RECOMMENDATIONS
OUTSIDE TEMPERATURE
Below 32° F (0° C) Above 32° F (0° C)
SAE/Viscosity
10W/30 or 15W/40
PETROL ENGINE - OIL VISCOSITY RECOMMENDATIONS
OUTSIDE TEMPERATURE
SAE/Viscosity
5W-20 or 5W-30
10W-30 or 15W-40
Air Cooled Engines
SAE30
If your chipper is not always idle after startup for a couple of minutes before running full chat, consider adding something like Lucas oil stabilizer for a bit of protection.
All oils etc can be had from your local motor factors. I'd recommend getting an account with them, it saves so much time. Just make a phone call and it turns up a couple of hours later.
Not recommending it but:-
In the war when they struggled to start Merlin engines (spitfires) in winter because the oil was too thick ( viscous) they added petol to the oil to thin it.....
They reckoned petrol evaporated as oil warmed up
Mind you the spitfires weren't designed to last that long either!
