Ms660 chain brake (again?!)
RobRainford
  • Replies 33
[QUO TE=Jonny Burch;1076699]Cheers for the post Rob. Did you just use an airline for blasting out the crud?
I used a combo of hot water and some flash degreaser with an airline. Had no other degreaser to hand. Still did a good job though.
Used lithium hi temp grease on all the moving parts
Caution, always wear protection when using an airline.
QUOTE]
Do you recommend Durex for PPE when using airlines:lol:
The things you Pros do in your workshops:001_tongue::lol:
For the slightly dim :001_rolleyes: - a pair of safety glasses is under a fiver and find myself wearing them around 60% of the time in the workshop - they are good for cleaning carbs with carb cleaner and doing any drilling or work with springs.
Eyesight is precious - you know it makes sense!
For the slightly dim :001_rolleyes: - a pair of safety glasses is under a fiver...
Not just the dim, the "Oh it's just two seconds with the grinder - i'll just squint instead" :thumbdown:
It's not the almost painless spark going in your eye that hurts - it's when it has melted into the eyeball and started rusting and you go to A&E to have the dye poured in so they can dig it out - that's the bit you really remember, then start wearing safety glasses.:blushing:
Regards,
Steve.
never had an issue with grindings. i tend to use safety glasses now and again. using a grinder i do. been caught out with fuel lines before. now that stings.
but looking at what you do in a workshop im suprised you are not made to wear them from the minute you walk in the door.
now if anyone wants pain i would reccomend arc eye..... now there is some serious pain.
Stripped my 66 tonight and now works like a dream! We won't talk about the shoelace that snapped in the cylinder though......
I left the clutch on and just did a general clean around it. Took the brake band off and poked around with a little screwdriver to loosen big bits. Airline and degreaser did enough of a job. Didn't fancy pulling the chain brake spring off as they are a pita to put back on!
Will be getting a bench top degreaser and doing all my saws
