If you are swinging it all day doesn't it make sense to get a hydraulic one?
I have an old maul that I paid £17 donkeys years ago. Wasn't expensive but nor was it cheap back when I bought it (probably 25 years ago). Split an awful lot of logs with it but have not picked it up once since buying a hydraulic splitter.
Swinging an axe all day might well keep you fit but it does wear you out, and I mean that literally.
The head is the most important part. Though the handle is a close second.
If it didn't have a handle the head would be pretty useless and if it didn't have a head it would be a stick :lol:
I bought a cheap fibre glass handled maul and broke a chunk out of the cutting edge in a piece of wood so I straightened the edge off with the angle grinder and tapered the head and it is now 10 times better than it was and doesn't stick any more. I usually swing it once then knock it through with a hammer if it hasn't split what I was hitting. I have a polypropylene handled felling axe that I bought for £1 from a flea market and it has been well used to good effect and I don't get hung up on what the best handle material is, wood, plastic or fibreglass they all do the job.
  • 4 years later...
I've built a lot of things over the years besides a fire whilst in the bush. Fences, shelters, windbreaks, crude washstands and once helped build a small dock. I've used a bunch of different axes and within my collection are a few I really like. For a wilderness trip I carry an Estwing hatchet https://bestoutdooritems.com/best-felling-axe/ in my daypack, a 28" 3 lb foresters style ax I got at a garage sale and a 24" tube frame bow saw from a hardware/camping supply store. The blade guard on the saw is a length of plastic tube with a slit and a couple 550 cord ties. A saw can be much more useful than an ax at times. On YouTube, there are a lot of interesting videos about comparing the quality of different axes, check out this video, I think it will not be superfluous.
On 06/03/2014 at 13:05, sandspider said:
I think the head on the X27 is lighter, so it takes more downward force to split. The Toolstation maul did it more by weight.
I like my X27 but also think it a bit on the light side. Great feel to the handle though, although a little perturbed to see it's hollow O.o
On 07/03/2014 at 14:02, BeanWoody said:
Also been looking at the new style (fibre glass) Husqvarana splitting axe - has anyone tried one yet?
My son tried out their range in NZ recently and rated them highly,
I have a husky maul, a husky smallsplitting axe and a wetterlings large splitting axe, use all 3 and they are the perfect combo for the work i do. It took me 10 years or so to settle on this combination and I've smashed numerous cheap fibreglass handled others. None were cheap, tho not too expensive and are likely to see me out, in fact number 1 son has already put dibbs on the large splitting axe as he is a smaller man than the younger one, who is a bear and can swing the maul all day long. I now seem to have taken on a more supervisory role which suits fine, and now mostly use the husky splitting axe do do the final splits after the boys break up the big rings.
