Trying to get an old 60's Stihl 08S working
Huskyswinger
are you starting the saw with the top on ?
make sure that the throttle linkage wire is working the throttle shaft it can miss when re-assembling
is the choke slider knocking the choke off ? it can stick the choke flap on ( some have a horseshoe shaped wire that knocks the choke off )
it's easy to check the above by viewing down carb when the airfilter is removed
  • Replies 22
The linkages are all correctly located and the mixture is set at 1 turn out.
I also replaced the fuel hose.
Even when the engine is running adjusting the mixture screws makes no difference at all which is odd as I've worked on saws before where it's a case of just adjusting the mixture but this is being a right bastard :-/
So to summarise:
got a decent spark
Compression reads about 105PSI
new diaphrams and gaskets on carb
adjusting mixture screws makes no difference at all
new fuel pipe
only can manage to get to idle with the trigger lock on locking the throttle to half position - even then its a rough idle and will not rev.
Crank seals then. Only thing is an air leak in the crank case causing it to run rich. This would also be why adjusting the carb isn't doing anything. As no matter how much you adjust it it won't get the right mix with the air.
Running on half throttle is enough to get just enough fuel to air mix, but not for long.
Best to get it pressure and vac tested.
Wouldn't that cause it to run lean?
very true. my bad.
but would still explain the rough running problems.
the compression imo is fine. 150 is about right for a second hand saw. it should run fine on this. have you done a compression test after it has been run up and warm?
very true. my bad.
Ok im just here to correct you :lol:
He says the compression is 105 not 150 so it is low :001_tt2:
as you were :001_smile:
