It's done a hell of a lot of work over the 18+ months it's been owned. Minor issues but mainly down to use and wear and tear.
It's done this lot in the last few weeks. Easily split 500 cube in the time it's been here.
  • Replies 33
Hi IRON a small tractor will run a 19t posch splitter pto power one a MF 35 does it ok thanks Jon
It's only 26 engine hp, or 18 hp at the PTO. Do you really think it will be enough? How much does the MF 35 have?
Might struggle with weight on the 3 point link to as she's only a compact.
Thanks Rob, thank speaks volumes! So 13T is plenty then?
Hi IRON MF135 45)48hp powers it easy ok your mini tractor too small mate I think it takes 35)40hp at pto power thanks Jon
[ATTACH]187332[/ATTACH]
Hi rob I see you use IBC mate are just left out side then do you cover them if so what with thanks Jon
Lifting is likely to be your problem. We have a 55 hp compact and the Krpan 18 tonne splitter and it's right at the limit of our tractors lift. If we had the Posch equivalent don't think we would have got it off the ground. If the weight was close in it would be OK but the weight on these splitters is a fair distance out from the hitch attachment points. Suspect when it comes to running it you would be OK most of the time. I run ours with the PTO on eco and it only stalls on the gnarliest of lumps.
Edited by Woodworks
35hp tractor is what runs our 9t machine , splitter is ancient atleast 15 years old would not like to guess how much wood it's cut, I think it's only on its second ram as well.
It's been working through arb waste of all sorts of shapes and sizes and hasn't really struggled. The two speeds on it means it can split at half speed but is much more powerful.
Leave them out in the open. Yard space is open to the prevailing wind so dries them lovely.
Hi ROB I see that but on top IBC do you Cover them rol Cover them rob thanks Jon
