whats wrong with dealer phoning customer and telling him your saws are bolloxed would you like me to strip them to find the problem thats what should happen
That's easy to say.
A saw must be stripped down a certain amount to be tested.
  • Replies 41
Exactly, if its not stripped then you cannot be 100% definite on the repair costs.
Its no good just saying its 'bolloxed' without providing the proof. Any dealer doing this will be branded as a rip off merchant.
Us dealers just can't win, can we?
I sort of have issues with this, too. I mean, at least ask the customer if he wants the saw back in one piece so he can sell it as a parts saw. I know it costs more money and time, but that should be included in your service, and you should inform the customer if further work is to be done, it would be easier if it were in parts. If they want it back together, put it back at no charge as you took the thing apart int he first place and charged them for it. If you are halfway decent, you should be able to put that saw together in a few minutes. Have the customer sign off on the form that he wanted it assembled even though it is non working, and why it isn't working, and let the guy have his saw back so he doesn't lose his parts. Also, I just feel like a failure if I return a saw in parts that came in to me nearly whole. I even put them back together if I know they are coming back to me later unless the customer asks otherwise, and in no small part because I want all the bits coming back to me as well and not ending up on the floor of their shed.
I at least would of offered to re assemble after a phone conversation to confirm saws problems etc common courtsy not that common thesedays was he miffed you did,nt either buy new or pay for a refurb >>> anyway glad your saws are sorted out now
When I was assessor got call to go and look at american mobile home belonging to a large national company
Somebody at co had told them to strip it down
They had left engine in bay but removed every part from it including crank, pistons etc ---
Utterly bonkers - they then quoted company £15k to put it back together
At this point company discovered someone had fitted a turbo so warranty was invalid
Garage were out to screw company, and thought they had them
Early days of internet, but I contacted USA and bought brand new crated engine for £3500 moved vehicle and saved them £10k
I could never undertand why they hadn't removed engine .....
Did something similar in mercedes main agent with international sports star
He'd taken it in with ' funny noise ' from engine
Mercedes agent had removed engine and totally stripped it to every component
Nothing showed lightest damage/wear so bill was totally down to him
He did it again following with another assessor
Exensive hobby
Have had both mercedes and bmw garages strip engines that have thrown a rod through the block --- just to check if its repairable !
Then invoiced customer for 8 hours useless work .....
I hate mercedes and bmw garages,
"the pom on the hill" like it:001_smile:
I hope we are updated. I would think the 200t needs crank seals and a bit of carb work.
Why did they take the flywheel off the other saw?
H-A
Why on earth would anyone put it back together at no charge?
As dealers we can't win.
If we use our gut instinct and have a quick peep at the piston, then tell the customer the cost of repair, we are only guessing at the internal, unseen damage. So we would have to quote high to cover everything.
Ok, so very little labour involved in this scenario.
So to be accurate we need to strip it, and prepare an accurate quote based on what we have seen. Again not much labour involved, saws are very quick to take apart. Often I do not charge for this, especially if results in a new saw being purchased.
But if we put it back together its going to take a long time, and whats the point? Just so that the customer can fleece someone on Ebay with a saw classed as 'running last time it worked'
When the E bay buyer complains to the seller, the seller blames the dealer who "repaired it but it still did not work when it came back."
The pictures of the returned saws shows no methodical approach to fault finding, but great cleaning skills.
If scored bore/piston was thought to be the trouble then pull the cylinders, don't just clean the saw and take the carbs off.
He did not take the exhaust off 200t, that takes little time, and shows a lot.
You can get the cylinder off a 200t in less than 10 minutes, instead he stripped the handle and took the carb to bits, a little strange.
H-A
But we only have half a picture here.The bits in the box are filthy, whereas the bits on the bench are clean.
There are tools on the bench indicating that some reassembly has already taken place.
I'll bet the OP has done the cleaning, not the dealer.
It would be interesting to know from the OP what the dealers report said, and how much, or little he was charged for the diagnosis.
Its a fact of life that none of us like to hear the truth when it involves money and often blame the messenger.
In my opinion there is little too much 'dealer knocking' going on on this forum at present without the full facts being made clear.
It was a long time since I was repairing power tools but I do believe there was a liability issue with reassembling, if you reassembled a faulty machine and the user was injured using it ....blah blah
Again guys, we have half the tale but are making some big assumptions
