Freehand milling
Daniël Bos
Did some freehand milling of oak today:001_smile:
I'm milling these trees for beams to construct a field shelter. It'll be oak framed with a reciprocal roof:001_cool:
So I need bits of wood of high strength rather than dimensional accuracy as all the joints will be unique anyway.
  • Replies 21
Just to clarify: The object of the exercise is not to cut straight.
Rather than straight, I cut along the lines of the tree following the pith.
The resulting beams are stronger than If they were cut straight for two reasons:
Firstly they can be thicker, as taking a straight line means that wherever the tree is not dead straight the result is thinner on one side, thicker on the other. Freehand following the tree avoids this.
This also means that the resulting beam has much less "wane". Where the tree has a natural bend I've followed it keeping the fibres intact. When cutting straight you'd sever the fibres resulting in a weaker timber.
Timber cut the way I cut it above is stronger than straight cut timber of the same dimensions (unless the tree was totally dead straight)
That's cool, so are you cutting with your natural feeling of where you should with experience ?
I just follow the middle of the tree really:001_smile:
I try taking into account the "side profile" as well to make sure that as well as following the centre line there is not one quarter getting too thin.
Could you clarify what you mean by this?
I understand the principles of what you're trying to acheive but I dont understand how you're "following" anything? It just looks freehanded to me:confused1:
