Hi guys
Is a buck rake any good for burning up brush in the woods? basically pushing it to the fire. Thinking of getting a push off buck rake so can easily get the brush off again.
Has any one used one before in the woods?
cheers
Richard
They're OK, but Hardox tines still bend and break.
If you have loads to do, you might be better with a proper brash rake. For odd jobs, I'd borrow a buck rake though.
Look up the price of the tines first, they are very dear.
Reckon on bending a few (or more!)
If my best mate who I owed an awful lot of favours and had saved my life many times asked me if he could borrow my buck rake to push up brash in the woods....
I would tell him to get
We use them to clear the prunings on 25+ acres of apples, you have to go very quietly.
Edited by Stephen Blair
Woodland means stumps so I would say no, unless It's built for the job intendered you will bend tines.
My old boss had an old silage buck rake was a good tool for light hedge cuttlngs but he still managed to bend 3 tines in 1 push.
Most, not all, but most woodlands have been "textbook" planted certainly in the last 100 years or so, is means that the trees are in rows, all you need to do is fell into the centre of the rows and brash will be clear of the stumps. Of course, common sense must prevail, there are going to be times that stumps are out of line etc.
We do lots of rake and burn and the stumps are normally buried out of sight in the lop and top. If you look at the rake on the machine on the truck you will notice a tyne missing, this must be 6" by about 2" solid steel about 3` long and that just ripped off on a stump. Very hard going because as you rake back you are building a mountain making impossible to see where anything is.
Bob
597668191f65c_(KGrHqJHJDQFDHIi69sBS(GBj0F!60_12.JPG.0e686995c3695ce21638431c3b9450d8.JPG I saw one of these with the tines removed and turn a round and remounted along back beam also some mounted pointing upwards looked a bit Heath Robinson but it work well.
Never done it but I would be wary of when you engage the push mechanism that a branch doesn't get snagged in the frame and swing round and hit the tractors cab glass or lights. It won't happen often but when it does :cursing:
Might but worth u bolting a sheet of steel across the front of the push fence and maybe extend a mesh above the back of the rake. Im paranoid by experience. Murphys law is dominant in my life. :- " Anything that can go wrong, will..."
