Just wandering what you guys use to sharpen up your hedge cutters? I use a small grinding disc on the angle grinder but was wandering if there was a better way to do it?
About right. Unless you want the expense of buying the proper tool. But unless you sharpen a lot of cutters it won't pay.
A small disc is the easiest way, but remember a cutting disc is not designed to grind.
I use a finger sander or a filing sander what ever you wish to call it, its basically a 10mm wide belt sander
Finger file or belt sander:001_tt2: a knew what you meant
I use a flat file, is this not correct then?
As long as the end result is a sharp blade at the correct angle a files perfect,i personally use an angle grinder because its faster than a file.
