hi need some info seen a land rover stood up apparently 18month sees green
it's a tdi h reg 6 wheels and they all drive
the owner says it's had done
300 tdi engine put in looks very clean and she's been rebuilt
the chassis has been stripped and seald wax etc says its work 6k on own can see that my self
only nightly bits need doing for mot all seals etc things I can see all look good and it's not got a drop off oil spillage under the body engine
it does need brake seals doing and they are shot being stod
on the back is a expedition box full of kitchen shower bedroom in side the truck he has put hot water tanks under the seats etc
my Qs is how much should I be paying for it and what will she be worth once she up and going for trees
as I will make a box 1.5ft over the chassis so can get more chip in and will be about 2ft higher than it is now
will also need to fit tipping ram worked out about a 500-1k to do
any help would be great
  • Replies 29
Popular Days
Nothing mate, its a good thing as is but if you turn it over to tree work that extra axle is just robbing payload down to an insignificant ammount
You say the engine looks clean, I presume then you have heard it running and it sounds good too. What gearbox? Landy boxes can be a tad fragile, auto stronger than manual, and what the effect of the extra axle is on that, who can say?
Why has it been standing so long?
Was all the work done by Foley?
Does the extra axle increase load capacity or count agin it?
Given you can't drive it I would offer very little,
It counts against it, a lot, makes it nearly useless payload wise
he's was working on the box at the back and took over his manger job and lost in street
engine purrs have not drove as seals need doing for brakes
the extra axle can lock so all six are in use or just 4wheel drive
he says when all six are use can tow and carry 1.8 extra tons
He is probably right but NOT legally.
It can weigh 3500kg all up, with a tipping body and 2 axles you usually get about 1000kg of payload that axle springs and drive shaft will eat about half of that.
The only way to use that extra capacity is to register it HGV which will give you about 1500kg of payload but will need an O licence.
and she's snorkled up so won't get stuck in ford
What happened to the damp mog..?
As others have said payload will be pants, will turn like an oil tanker, but look great..
