Welcome to forum Newbie. :biggrin:
As a starter rope, you can't beat Yale XTC. Virtually bomb proof and will last you a long time if looked after properly. Excellent value for the price.
And unless you're going to be climbing "big" trees often, (doubtful), then 37m is plenty long enough.
Hi what climbing rope would be good for a new climber and what length
All depends on if you are up apple trees or red woods if you see what I mean . No body wants to lug more rope than they need but no body wants to be short ...
If you're only buying one rope, get a 45meter. You will come across a tree sooner or later that will be bigger than a 37m is good for. Its very foolish IMO to climb a tree without a rope long enough to get down in one hit.
If you get a 45 mtr rope I'd recommend ringing round the dealers and see if they've got any end of reel bargains, a 10/15 mtr is proper handy for dealing with the small trees
Sent using Arbtalk Mobile App
What he said and what others said about the XTC
Personally I climb with a shorter rope as it's easier to pull about and manage ,I have a 45 m but have probably only used it 5 times last year its a pita to manage if you don't need the length. I take a second rope any way so will install that lower down and switch over if extra length is needed but the trees around here are not massive!
