5th wheel coupling to tow a bandsawmill
difflock
  • Replies 20
Rover, that would be the absolute simplest solution, providing up to a 12m trailer.
But;
(i)Owt over 3500kg = tacho for "hire or reward", which hire or reward being the only reason I would wish to take the Mill on the public highway.
(ii) I more than suspect that "up-plating" is so much more difficult than "downplating", in respect of Axle capacity, final drive ratios and better brakes required for the greater loads.
A few of the Styer Puch's visually identical to mine, were plated at 4000kg/4500kg, BUT with uprated axles with lower final drive ratios.
Might do some homework though.
marcus
Simplest solution though is to buy an Iveco van/chassis cab plated at anywhere over 4000kg
I could be wrong (it has happened before, 1982 it was..) but the way I understand it is whether or not the movement is for hire or reward, for example moving the wood you are to cut or the planks you have cut to or from a customer. Moving a tool to use in your trade is not that and thus exempt?
I was wondering about the status of the mill once its all together. Is it not then a piece of plant and not a trailer anymore?? What defines something you tow as a trailer.?
Bob
That would be an accurate description for the conditions of an operator's licence but in general terms moving a sawmill to a punters property to mill their timber will probably be an activity for hire or reward.
The test of that would be, if you didn't move the mill there would be no hire or reward, therefore moving it to the area its going to work in is part of the hire.
