Hi all,
I'm making lamps using cross sections of tree trunks as a base.
I've been using deciduous wood such as oak, beech and hornbeam. I've been using these woods as they are heavy when seasoned so make good bases for my lamps.
I have the option of felling a eucalyptus so I wondered if anyone knew of its properties in terms of would it be a heavy wood once seasoned such as the woods mentioned above?
Thanks.
Danny.
if your'e going to use it for fire wood then cut it into log size you are going to put on the fire straight away as you cant split that stuff...
to use for your purposes you can wait for he whole log to semi season (takes a few years) and then get it milled. see this thread to see what i mean.
http://arbtalk.co.uk/forum/milling-forum/45162-anybody-milled-eucalyptus.html
what sort of sizes are these bases?
It will split unlike any thing you have seen!! Half inch diamonds across the rays approx 3" apart .. Also the worst wood to try and split dry but ok wet.
