Wow, that meteor is huge. I'm gonna go clean up that cylinder now, I reckon.
It gives a lot more potential but would make sure you ask your supplier about it before going mad - you can use the link for guidance!
Done yours for starters and got a 357XP to do:thumbup:
Nice 1 :thumbup: what did you set the rpm too? I'm happy with that saw, got it it for £211 of ebay :001_smile:
It has a limited coil but you can feather it up to 13,900 and it juuussssttttt goes loopy at the very end so low 14000 - it may take more but like to build in a little safety! Check the plug colour after a good bash with it - coffee colour is good!
Lucky I found the leaking seal - would have been toast very shortly!
I hope you didn't grind out the tonsil if it had one on the intake side? That's to keep the ring in check.
