if its going to be looked at then i would simply sand to a fine grit and give it a coat of poly-x from osmo as it won't leave a shiny finish giving you that rustic look your after.
osmo really brings out the grain in my opinion and will make it look great.
where did you get such a big bit of olive? pictures???
  • Replies 27
yes i know kevin. Mr bolger i believe. i do love the south African accent...
i met him through ebay years ago and got some nice apple amongst other things, never been able to see his site though as i can't drive but if anyone is passing taplow on their way i'll happily tag along...
  richardwale said:
It's approx a metre tall by 300 wide. It's going to be be wall mounted so needs to look the part! The board is olive tree.
ah! thanks for explaining!:thumbup1:
where did you get such a big bit of olive? pictures???[/quote
Hi, so the stuff to buy is the osmo poly x hard wax oil? Does that simply paint on?
Osmo poly X is the business. I apply with a rag unless it's a very rough surface, where I use a brush. Leave a couple of minutes and wipe off with a clean rag. 2 coats is usually plenty
  dannytreacy said:
What are your thoughts on Danish oil compared to Osmo? I've been using Danish but am happy to switch to Osmo if it is a lot better.
Cheers,
Danny.
Osmo poly X in my opinion seriously out classes Danish oil. Buy some try it once and you will never buy Danish again!
Read more
