Having very nearly lost the sight in one eye a couple of months ago whilst hedge trimming, I've started to wear goggles/glasses under my visor. I picked up some at the APF called Safe Eyes which seem
Ok. They are the fine mesh sort so misting up no problem, not amazingly comfortable but for £10 can't complain. Pretty sure there are others out there which may be better design
Sent using Arbtalk Mobile App
I've had loads of different pairs of various makes - I haven't had a problem with any misting up. The trick is to wash them once a week or so with washing up liquid, this stops the misting!
Currently using bolle trackers, I'm pretty happy with them!
We use Bolle anti fog as these seem to be the longest lasting with the best anti fog coating. A little more expensive than the run of the mill but it just means you take care of them better. If they work well you tend to wear them all the time. Wash them under running water rather than using a cleaning cloth as using the cloth just rubs sawdust etc around the surface of the lens and removes the anti fog coating. Part of the PPE at council and must be worn unless wearing them proves to be a greater risk than not.
For me the pfanner glasses didnt fit that well whilst using ear defence. The tips of the arms that go around and behind the ear would place more than usual pressure making them uncomfortable after long periods of wear time
That's where the Bolle contour scores well. The ends of the arms are flat and curve around the head so they are comfortable under ear defenders
Yep and the stein k's 👍
