  • Replies 29
Does it just hook up to a car battery or can you use it from the mains as well?
Nope only battery but would be bonus if could use mains!
Iv got one the only time I use it is when the saw is on a mill
overwise I use one of chainsawbars edge save files I like filing I think they cut better
HI BURREL what do you think of edge files im told there very good thanks jon :thumbup:
Thanks all for the endorsements!
Can't really add anything really - out the box you need to spend a bit of time in the workshop getting it set up (I use a jumpstart pack to power it...)
If you try and use it out the box on a wet and windy day then it will seem fiddly and awkward... but once you have the hang of it it is such a good little tool for getting consistent tooth length...
I file or freehand grind inbetween using it.
I can't believe you haven't used yours yet Jon - You must of had it for 6 months now! :001_tongue:
:001_smile:
