Smoke and lots of it!
Old Mill Tree Care
I used my 395xp for a few hours on Monday and it was perfect.
It struggled to start the next day and then ran very smokily without improving.
It's slow to pick up when I squeeze the trigger and needs several pulls to start when warm. Usually starts on first pull.
It's always been run on Aspen.
The weather is extremely humid but my container is not too bad inside. (dehumidifier).
The smoke is quite white, to my eyes.
Any thoughts guys? I am panicking as it's my only big saw.
Thanks.
My first thoughts, had you not been using Aspen, would be contaminated fuel.
Of course, this still could be the case depending on your fuel management.
Is it possible that some chain oil has been added to the fuel tank in error, maybe just a little before the mistake was realised?
In any case, I think my first action would be to drain and flush the fuel tank, refill with fresh Aspen and try again.
Good luck.
Barrie
During the summer I had a climber fill two saws a 460 and a 200 with oil in the fuel tank in realising what he did he emptied it and rinsed them both out the 200 was fine the 460 smoked like a bitch while trying to get finished. He stripped it all cleaned it all and reassembled fine. Same climber filled a 338xp with oil 3 weeks later saw in skip lad down the road.
