346xp
Yorkie
between 4&5 foot diameter at base. it has had bleeding canker for a few years and the wind snapped the trunk near the base today.
So 20" ain't gonna halve it, stick with the 15" and cut it into blocks, similar to a #, with a name like Yorkie I assume you're based in Yorkshire, just advertise a play day for saws and I'm sure some on here would blitz it up
Sent using Arbtalk Mobile App
  • Replies 20
I find 15-16" ideal for balance and handling, and personally prefere 16".
13" is out, as the saw becomes rear heavy.
Any longer than 16" becomes a tradeoff of need vs. handling and performance, but a 20" is fine if you really need it.
Edited by SawTroll
I went up to 18 on mine from the 15 and yep it cuts a tad slower but it still does the job and I'm happy I did it
No surprice there, but be aware that the chain model that is used may actually have a larger impact on the cutting speed than that differense. :wink:
Another issue is that the handling of the saw suffers from the longer bar, specially when limbing and such.....
Edited by SawTroll
Yep it does feel a tad different but I like being able to use In tree for longer before swapping to a bigger heavier saw. And I weigh about as much as a 346xp so it's a huge bonus to me to not have a bigger saw on my harness!!
An xpg might topple you over then! :thumbup:
Surprised at that. 13" makes it a fantastic snedding saw. The day I put that size on I had a grin that just about split my face.
13 and 15 are good. Trying the 18 on bigger stems when climbing
