As per title, fine one minute, dry the next.
Dumped the oil and there was a fair bit of crud in there.
Swilled it out with petrol and ran it up with the sideplate, bar and chain off, nothing getting through.
Had an airline in the tank and blowing into the feed hole from the side, still blocked.
What next?
Thanks in advance.
  • Replies 20
Have the pump out, mine did that, take casing off over pump and have a look, the pipe going into pump on mine was proper blocked
Sent using Arbtalk Mobile App
What next?
Thanks in advance.
Plastic gear stripped ? .......get a T540 !
Take the oil pump out and give it right old clean out...
Squirting WD40 in there will hopefully clean and blast any crud out. Had it with a problem on one of my saws and it sorted it a treat.
Pump out and work it backwards while squirting the good stuff down it. Then check the feed pipes from tank and the rubber gromit bit that feeds the bar channel.
While your there check the worm drive gear is all good. Also check the clutch is engaging the worm gear ok. As in its sitting in the grooves on it.
