Pulled the bag that the chain came in out of the box.. 45 drive links :D
That's one more than a stihl? But that is what the book says
Sent using Arbtalk Mobile App
  • Replies 92
Both bars obviously are shorter than "called" - but that is the case with all 3/8" lo-pro/picco bars, except the Logosol bars, for the 066/660 etc.
Just a point to note . You can have two different saws with to identical bar lengths , working length from tip back to saw body , with different numbers of drive links because the drive sprockets are a different distance from the front of the saw body to where they mount on the crank shaft end .
  • 4 weeks later...
I got the 201t a couple of months ago and it has been an absolute dream to use, hard wood, soft wood, big wood, small wood, kills it on every level! Strongly recommend!
Glad you are happy with it . Ours is pants to be honest . Have you tried a T540 ?
Nowt wrong with the 201, well yet husqys fine for first 6 months to a year then the problems start. But would say bring back the 200t best climbing saw ever ran mine into the ground to get it going again needs rebuilding.
The T 540 has not been out for a year yet . How can you say problems start then ?
