A Eucalyptus log.
HI dismantled a Eucalyptus gunnii about 6 weeks ago. The client said his dad would use the wood for something but this hasn't happened.
The trunk is still on the lawn and now my client wants me to carve a basic bench or something.
My question is:
How will Euc react to this in terms of splitting, cracking etc?
Thanks for your time?
on that thread it says that woodturners dont use it, well thats cobblers.
eucalyptus is a beautifull timber and E, gunnii can have great colours in it likes pinks and greens. my sisters tree had to be taken down and i had some of the procedes as a novice turner at the time. the items i made didnt split that much and it turns very well, the secret is in the drying process. i dont know about planking but for a decent sized bowl you will need to rough it out first and finish turning it when its dry and the speed it dries it should only need a few weeks.
carving a bench is probably not the timbers best use but it wont fall appart, it'll just have alot of holes in it...
depends on your point of view jon.
lots of turners will tell you that the bottom of the bowl should point towards the middle of the tree for stability reasons, so by that reckoning the last bowl is correct. many bits of wood are quite small and when that is the case i will smpily slit the log and use the natural curve of the log as the outside or give it a natural edge like the eucalyplus here.
