Stumbled upon this and thought I might book myself in, could be an interesting day.
Anyone ever seen a scrap of Industry or HSE guidance on using a Tree Shear?
Anyone else ever seen any Training Courses for one?
Eddie.
Eddie.
Never seen a thing but think I might go to.
John
John
I wonder if they do on site training, they can come out to my Liebherr!
Joking apart it’ll come, but based on and benchmarked against what?
You fit a Shear, if the machine can lift it then it’s good to go, open the roof hatch, front window and door, grab something, if it cuts it great, if not wiggle until it breaks off anyway, if you can hold it good, if you can’t throw it before the machine tips over and repeat.?
Eddie.
Eddie.
I wonder who came up with the course content?
It’d be very interesting to hear your thoughts on what is delivered Eddie, as you obviously have a good deal of experience in using tree shears on sites that already require a lot of ‘hoop-jumping!’.
If nothing else it is an extra piece of paper to stick in front of a difficult site manager to show competence - it would be good to know whether the course is actually fit for purpose in the real world (and not just a training-provider exploiting a gap in the market).
be  Interesting to see what certificate / qualification is offered, am chasing similar training and assessment at the mo , we are looking at FMOC based to try to get recognised and acceptable  for clients
I have worked out how to bring in sensible guidelines that at least ensure the base machine and Shear are compatible and the machine setup correctly for it’s intended use without massive hoops or needless expense.
Also the basics of a sensible course content for Operators of such setups.
Problem is where do you even start?
I’d have thought better to go to the HSE now and say these basic steps will go an awful long way to bringing more compliant setups and competent Operators, than await a tragic accident, with the inevitable heading off to the Forestry industry for an answer they won’t find there, as it’s a new industry Mechanised De-Vegetation.
At this point CPCS covers all attachments on a 360 and a Tree Shear is not a lifting appliance.
It should be tested under Puwer to give evidence that it’s in good order.
FMOC of no use whatsoever on any Rail or Highway project I’ve ever been on.
Eddie.
At some point there is a risk of a cut and hold shear operator grabbing too big a piece and pulling the machine over on a site where it would (rightly) be reported, or where the consequences lead to injury or worse on a site where it may otherwise not be reported for whatever reason...
At that point I’d imagine the powers-that-be may determine a cut and hold shear actually is a lifting appliance, and everything will become a lot more complicated (calculating potential applied load with a safety factor may lead to insistence on hugely oversized carrier machines - the weight of the shear itself is only a small part of the ‘lift plan’).
A recognised industry-accepted competency needs to become a reality before insurmountable red tape is forced upon us!
A Cut and Hold Shear is fine if the base machine is simply large enough to carry it and the bit between the levers and seat a reasonable level of competence.
To raise the factor of safety you lower the cut capacity and increase the carriers lifting capacity, either more weight or less reach.
I have worked out a very simple formula that each setup can be benchmarked against.
It ignores absolutely everything in terms of the machine spec/load chart etc and works with the actual setup presented for compliance inspection.
It’s never going to be perfect, but it would represent a massive leap forward in terms of safety and is extremely simple to understand/implement.
What it would also do is allow guys who don’t quite comply to have many options to do so without huge expense.
If anyone knows where to start I’m happy to sit down and put the case over.
Eddie.
Could do with finding a cheap micro or mini digger in the next couple of months.
Main job is to help us on a planting job we have coming up to dig trenches etc.
Other uses would be use at home for renovation and landscaping and maybe go out with the stump grinder also to help clear or level the arrisings.
Looking to spend 4-6k what can anyone recommend? Or any help thanks. Not a high budget and won't get used a lot at all to be fair
