4 hours ago, BunyipBen said:
Hi Guys
Looking or advice again, talking about trailers to tow a 6 tonne machine. I am about to be approved for finance to purchase a machine here in Australia and will need to buy a trailer to float it behind my Unimog U1300L. I am looking at tandem axle trailer with ramps that has a flat bed length of 2.9m before the angle drops down with the beaver tail. I have no experience loading and transporting equipment so I am a bit helpless to know if this trailer will be a good match. The photos show the trailer as is now in blue and white and I got a picture from the manufacturer of the trailer as it originally looked. It is rated to 8000kg total trailer mass. The other pic shows the dimensions of the Hyundai R60CR-9A I am hoping to acquire. I see guys transporting machines with swing boom that sort of slew the cab around and have the boom offset to shorten up the total length, is that the go? Another question is regarding the mass that can be expected to transfer through the drawbar and hitch with a setup like this, would I be right in estimating around 10% of the trailers gross weight?
Thanks for you assistance
Ben
that trailer looks incredibly short. I dont think my 3 tonner would fit on it lengthways. My indespension trailer is 10 foot and the arm hangs off the back as there is not enough room to pull it in tight enough at front and not hit towing vehicle when it corners.
Not sure on the laws in Oz are you allowed to have 8 foot of digger arm hanging out the back of a trailer ?
Rear overhang on a pig trailer must not exceed the lesser of the length of the load-carrying area, forward of the rear overhang line or 3.7 metres.
So assuming the flat bed measures 2.9m as I am told by the seller at a guess it would be close to around 2 metres overhang behind the centre point between the axles, which may work out to be something like 750mm past the rear of the trailer??
Thats why I am interested to know about the position of the arm for transport?
52 minutes ago, Stephen Blair said:
Sweet- could do with that on my job at the mo- flippin massive rocks trying to wrestle Into position with my 3 tonner for dry stone walling- can just about drag them along the ground! That one you have in the bucket probably weighs 2 ton. A cubic meter of granite is about 2.6t.
It looks the same length as my red multi purpose dump trailer I use for moving my 3 tonner around. The total bed length is 12ft and I could just fit a 5-6t in there with arm out the back, I can also fit it in with the arm out the front with the bucket resting on the headboard- I prefer it this way as the bulk of the digger is over the trailer wheels- not on the hitch of the tractor. I think a mog doesn’t take hitch weight as well as a tractor either...
Bunyipben - my Takeuchi in the pic below is a 6 tonner, and the trailer is 14 foot (4.2m). It is loaded conventionally in the pic.
The Cat is an 8 tonner in the same trailer and has to be loaded offset as you describe to get the rear overhang down (in fact, simply to get the bucket/end of the dipper onto the trailer bed to secure it for transport). This offset arrangement would be more difficult with the trailer you are proposing as the ramps would restrict options.
I’d think you could move a 6 tonner on that trailer as your tracks should easily park on the flat, the blade may be on the slope but that’s not a problem. There would probably be a considerable implied load on the drawbar at Matt has suggested, and the boom would certainly hang out of the back. Can you not get the seller to get pics of a similar sized machine loaded up?
The first pic- does your Tak fit on that trailer with the 600 tracks on? Also how do you find that amount of hitch weight- mind is quite bouncy with the digger that way round but my tractor is quite a bit smaller which doesn’t help.
Yeah, plenty of room. It’s on 550mm tracks which are wider than the standard blade but I had extensions made (that bolt on) taking the overall width to 2.4m - slightly wider than the tracks. It all fits in the JPM no problem.
The 8 tonne Cat is very tight width-wise, on standard rubber, but does go in.
Weight-wise, the 6 tonner doesn’t actually put too much on the hitch on that trailer - you have to move it a fair way forward before it transfers any weight at all onto the tractor.
Edited by monkeybusiness
I’d say you are right about the weight, the machine moved it effortlessly , the side shift power in the back actor is a huge difference compared to wrestling with 2.7tonner.
