Any thoughts on HOLP rototop ? There is also another similar product around but can't think of its name right now.
Holp GmbH ? Startseite
If that's what you need I think they're a great bit of kit.👍
Gregor McArthur has done some, there was one on a CAT308 if I remember correctly at the APF a few years back. Best thing is the flow and pressure they will accommodate through them, so obviously ideal for power hungry Mulcher's and Stump grinders etc.
From seeing them first hand I think the quality is without question.
I'd say if combined with an Oil Quick hitch setup it could be a real contender against conventional Tiltrotator setups in some applications.
The shaped bucket they make is fantastic, and one of those under a Tiltrotator would be pretty special.👍😎
Eddie.
I got an x2500 on the recommendations made by Matt. I've found it to be great. My only addition is spend the extra on the two pin with cradle. I went with the standard one pin and you are often waiting on it to stop swinging before you can get started.
Sorry Richy- I should have mentioned about the cradle hitch to you before you bought, as you say a must.
Glad it's serving you well though.
Keith your tb230 will probably take the x3000 if you are after big holes 12" plus- augertorque know their stuff though so will advise better.
Thanks for the replies.
I had been looking at the augertorque units, dealer is just getting me a price for it all.
