Yeah its imprinted on my mind for all eternity after hearing the sound of metal chunks clanging out the chipper shoot.... laburnum 5" diameter
my old ph25/t/w thru a blade straite out no damage never found it
  • Replies 40
I have seen blades bent (after a ratchet strap found its way through). Yes the front edge was damaged but no shattering. This shows a good level of hardening & tempering. Blades were Original TW. Most important thing (pattern or original) to remember is the keep them sharp as this reduces the loading on the blade & associated parts
I use both genuine and copy blades, though 90% of the time ive gone with saturn blades due to cost. The only blade ive had fail in 6 yrs, was this timberwolf one.
that was a well worn blade. note the score line for wear limit. I throw mine away well before they are that bad.
could it be that older blades at the end of their working lives are most likely to fail.
  • 2 months later...
If your blades get down to 60mm or less they can get 'jacked' off the flywheel. Also we went through a spell of using pattern blades and the same used to happen.
Edited by Steve Bullman
No disrespect but the blade looks knackered even before it broke .
Err...........look at the picture, its not reached the end of life line on the blade, so whats the problem?:confused1:
Yeah i always make sure i run knacked blades... especially ones which which look like they might disintegrate on impact :sneaky2:
Seriously though , those blades seemed ok prior to destruction.
