I don't know if this is the correct place to ask, I searched and couldn't find the answer.
I have a HS45 an FS90 4mix and soon will probably be getting an Echo cs352. So the question is, what IS the best 2 stroke oil? I have been using the Stihl red but now I need some more and have seen that Stihl recommend the Stihl super for the 4mix. But are there better oils? Something that will be good for the all my stuff. What do you guys use?
Thanks,
Marc.
  • Replies 52
The best 2 stroke oil is " Red Line Racing 2 stroke oil " From Opie Oils but totally unnecessary for your requirements . You did ask though ........
So looks like the Stihl is quite a good choice then? That's what I was going for TBH. No offence to the Aspen fans here but it's too expensive and I have not seen it around here. there red diesel is cheap though at £12 a gallon!
Thanks for the replies, keep them coming,
Marc.
