  • Replies 65
as all other posts the takuchi are good machines we have been using a 2 tonne kubota that has so much power brill machine and has a longer dipper arm so will dig deep Harper plant salisbury
Mini diggers have the ability to make a huge amount of money, more than a chipper for example I would say, I'd not look at a chipper with 2000hrs on it but that's about half way through a mini diggers trouble free life. If all the fluids are changed regularly than they usually don't wear out much and have a very high resale value.
I pretty much run my business of my mini along with its various attachments (auger, grab and post knocker) I use it for fencing, stock proof and domestic, scrub clearance tree work, stone walling and of course general excavating and landscaping. Best bit of kit I own
Is the thumb attachment useful for extracting logs from woodland and lifting onto a trailer? If so how much weight can a 2t digger take ?
Assume better to buy a digger than a forwarding trailer with grab as at least it can be used for other jobs ?
The thumb is brillant at loading wood onto a truck loose, it would not be as good as a rotator for real forestry, mine lifts 350kg perhaps more;
Edited by Le Sanglier
I have a bob cat e14 kubota engine. its never broke or failed to start. its got loads of power.it will pick up half ton. real good to drive the controls and cab are very well spaced and I am quiet happy to sit in there all day long.
