362 or 560???
Tom Hall
  • Replies 74
:confused1: Thats odd - the 560xp should have absolutely no issue with .325x8 with any sensible bar length.
Yea Buried the full depth of the bar in some ash and it just shut down . Its had some mods since then though so might be ok with it .
How much time did you give it with the 8-pin? It could be that the AT needed a little time to adjust for it.....
Kept trying , kept shutting down . It is a 2011 saw , one of the first . Since I bought it in 2011 it has had a new updated carb , a remap , and some other bits not engine related . The main mod has been done by petemate on here . He removed the cat from the exhaust can and did some other " tweeks " , possibly some porting but not sure on that . Don't think there is a great deal you can do on that front as its pretty good as it is . but the muffler mod and whatever he did to the mapping has been superb . No hot start problems , in fact no problems at all . :001_smile:
Ok . Well whatever it was in there he took it out ! Its as loud as a loud thing and you can see the weld line where he cut and shut it ...
Probably the baffle plate, derestricting air flow, allowing more flow
Sent using Arbtalk Mobile App
