UPVC doors
lawranced1
is it a new ish door?
well, if not the rubbers on the inside come out, which loses the tension on the outside beads,
if it is newer, the inside beads come out, by putting something thin (putty knife / filling knife)
pm if you want to know more
or send a pic and i will try and tell you
If beading doesn't just pop out by using a chisel or the like, sometimes rubber seal between beads and panel will pull out making it easier to get beads out, alternatively could you cut hole for cat flap with panel in situ?
