Timberwolf issues
likeitorlumpit
Bad end to the day yesterday.
Stopped the 150 and it wouldn't restart.
All we get is the clicking from the fuel pump. No starter action and no light on the ignition.
Have taken off the injector solenoid to check today but not hopeful.
Has anyone else had similar issues and is there an easy fix.
Thanks in advance
  • Replies 20
The ignition switch where you put the key could be dodgy, on the first position it switches on the fuel pump and second position should put the light on then third it should engage starter. I had it on mine and it was a bad connection on the back. Take out the 4 screws and have a look, you could take the wires off and short out the connection to see if it turns the starter.
Sent from Outerspace.
Thanks for all the suggestions
It's not battery nor starter - it's definately the clicking from the fuel pump.
Cheers for the tip- I've used that hammer trick before on many things:001_rolleyes:
I'm talking with the fitter friend later and hopefully he'll have some solution.
Will let you know
